Evaluate and @Mailsend gives Doclink problem
Hello,I’m using in QuerySave event on a form a script which sends out status mails.
Unfortunately no mail goes out as soon as I try to add a doclink.
Works :
Const NotesMacro1$ ={ MailSend(“MyMailAddress”;“”;“”;“Follow this link”;“”;“body”)}
result = Evaluate(NotesMacro1$,doc)
Does not work : ( no mail sended, no error )
Const NotesMacro1$ ={ @MailSend(“MyMailAddress”;“”;“”;“Follow this link”;“”;“body”;[IncludeDocLink])}
Also ; this second code, which does not work in the QuerySave event, sends out the mail but without the doclink when I put it in PostSave or QueryClose event
The doc has been saved before.
Is there a restriction on the Evaluate or is it not possible to do it this way ?
Thanks and regards,
Ronald
Subject: Evaluate and @Mailsend gives Doclink problem
Ronald,
Does your database have a default view??? The lack of a default view in the database stops the [IncludeDocLink] parameter from working
Mike
Subject: RE: Evaluate and @Mailsend gives Doclink problem
Hi Mike,
You made my day , works like a charm.
Thanks and regards,
Ronald
