My 8.5beta1 server’s name is d8/wtslabs.
When I make design changes using DDE in database on Local, everything is OK.
However, when the database is copied to the server, everytime I save the changes, a new error message is added to Problems view:
The project was not validated due to “Can not create a Resource at the location : jnsf:/d8_2fwtslabs/XPagesTutorial.nsf/bin”. Fix the problem, then try refreshing this project and validating it since it may be inconsistent
It seems that “/” in the server name is replaced with “_2f”. However the changes on design elements are saved properly.
