Since the command @Environement cannot be used in columns nor selection formulas, anyone has an idea how I could build a SELECT using the same value as my environement variable ?
The user must enter a username (which is set in the env. variable) on the login form then the form is closed and a view is shown. I need to built my selection formula for the view based on the username.
By which Chris means: you’ve got a bigger problem than @environment. One of the single most-posted issues in the forums is how you can’t use @username in a view, and the common workarounds, which he mentions.
