hcl-bot
September 17, 2007, 1:19am
1
Any suggestion what the reason since Envelope icon not showing in system tray when new email is received.It is checked to use use that option under User Preferences.
I have deleted the Cache-file and checked that it is Correct Location document with Correct data.
hcl-bot
September 17, 2007, 3:02am
2
Subject: Envelope icon not showing in system tray when new email is arrived
I think that this is one of most lotus’s strangness.I tested the function with success yeterday.
Instead today don’t work yet.
I have matched lotus.ini before and after the setting but i’ve not found any difference between 2 files’ version.
Will they succed our heroes…
Try these :
NewMailSeqNum lines in notes.ini
There were two rows containing info about NewMailSeqNum. Delete both of them and left one NewMailSeqNum= empty and restart notes.
http://www-10.lotus.com/ldd/nd6forum.nsf/55c38d716d632d9b8525689b005ba1c0/5cf23329c605c23285256fb000406b1e?OpenDocument
‘inactive icons’ list of Windows XP
Rightclick on the system tray - properties - taskbar - ‘hide inactive icons’- customize. Set the new mail icon to ‘always show’.
http://www-10.lotus.com/ldd/nd6forum.nsf/55c38d716d632d9b8525689b005ba1c0/7b323f170b5ae5c4c1256e210057074f?OpenDocument
