' Entry Not Found In Index ' using RULES
I’m using Notes Admin Client ver 6.0.1. Trying to create RULES but theabove message appear. What am I missing here?
Thanks in advance for any help.
Subject: ’ Entry Not Found In Index ’ using RULES
You are probably trying to work with the RULES in the server document. You should go to the Server/Configuration part and there it works just fine. (had the same problem, so…)PS : i had my server first setup to use the configuration for all servers. This way, it kept on giving the same error as well. So create a server config for a specific server.
Subject: RE: ’ Entry Not Found In Index ’ using RULES
Works like charm now.
Thanks a zillion.
