Hi All
I have a weird problem with R6. I have a web agent running on behalf of web user with run time security level set to 1.
This agent tries to print a domino url
server/db.nsf/(view)/key?editdocument
it doesn’t work and i keep getting HTTP Notes exception :Entry not found in index.
if instead of using the key i use the document unid it works perfectly fine.
I have checked that the (view) has a first column which is sorted by this key value.
Has any one ever faced this problem ?.
Thanking You
Siddharth Pawar
