Is there a product wich can customize easily the domain index and index on filesystems? I have seen a product from Copernic Enterprise search wich i liked very much.
Its not quite the same thing, but I have a product called “NCT Search” which is designed to search multiple Notes/Domino databases and return a high customizable result.
The PRESENT version does not directly support the domain index, but instead performs the searches on each database and colates the results. Its actually quite fast and avoids overhead that way.
The version about to hit BETA (and release I hope) will support the domain index and also will support specific view searches in databases as “searchable objects” in addition to just “databases”.
The point of the product is that its easy to set up, and easy to customize. It also lets you do things like specify exactly what to return from a given database as the result text, and even what documents NOT to return (like config docs and keyword docs).
PS to forum denizens-- Roger’s request was emailed to me by someone who reads the forum, as I cannot keep up with it. I appologize in advance to those who feel this is an abuse of the forum, however I feel answering a specific request like this is within the acceptable bounds. In any case, you’re welcome to write me to say otherwise but posting here will not help as I probably won’t see it.
