Encrypted mail forwarding problem
I have an agent to forward email to helpdesk.if email is normal email, the following coding is work fine. but if the one of the email encrypted, the code is stoped, and the rest of the email document cannot be forward.
anybody help me with this?
Many thanks!
Sub Initialize
Dim db As NotesDatabase
Dim collection As NotesDocumentCollection
Dim docA As NotesDocument
Dim docB As NotesDocument
Dim SpringUser As notesname
'Getting all the documents that approved mailbox for action,
Set collection = db.UnprocessedDocuments
Set docA = collection.getfirstdocument
While Not docA Is Nothing
Set springuser = New notesname(docA.from(0))
'Create a new document
	Set docB = New NotesDocument( db )
'Copy the contents to the new document
	Call docA.CopyAllItems( docB, True )
'Assign new form as Memo
	docB.form = "Memo"
	docB.copyto = ""
	docB.blindcopyto = ""
	docB.subject = docB.subject(0)
'Send to Spring_helpdesk@juzcall.com.sg
Call docB.send(False,“spring_helpdesk@juzcall.com.sg”)
'Mark the email as processed
Call session.updateProcessedDoc(docA)
Set docA = collection.getNextDocument(docA)
Wend
Subject: Encrypted mail forwarding problem
The message can not be forwarded without first decrypting it.
You’re trying to run this code in an agent that is running without the private key that is required to decrypt the message.
There is no magic solution for that.
But you can at least move on to the next document. Use an “on error” statement and a “resume” statement to trap the error and continue.
Subject: RE: Encrypted mail forwarding problem
Thank you!
