This is what a posted some weeks ago:
- ViewCollapseAll does not work on embedded views:
- I created a form with an embedded view on it. The view is categorized and ViewExpandAll works as expected. But ViewCollapseAll does nothing. Neither the toolbar button nor the standard menu action seem to work.
- Session.UpdateProcessedDoc does not work on embeddedview:
I am trying to embed a view onto a form. I set the view to display its action bar so I can use its agents to process selected documents. But calling session.Updateprocesseddoc does not deselect the documents after processing and even the menu action Edit-Deselect all does not work.
These seem to be Notes 6.x design bugs - could ANYONE confirm this? Is this being fixed? Or should we just wait for 6.5 ???
Josef
