I have an embedded calendar view in a form and 2 datetime fields. When I change the date in one of the field, the calendar go to the date and this is perfect, it shows that there is some way that Notes can access the calendar.
The problem is, I can’t send any command to the embedded calendar!
I only need those 2 commands to work when the form open(onPostOpen). This should be simple…
@Command( [CalendarGoTo] ; @Date(2009; 12; 01))
@Command( [CalendarFormat] ; “20” )
They work perfectly when the view is not embedded, but fail otherwise. CalendarGoTo even say “Cannot execute the specified command” when I try to open the form.
I have been searching that for a long time now, on google and on the forum here, it seems there is nothing to be found. I’m sure there is a solution somewhere for something that simple!
Thanks.
