Elementary problem with JS
Hi.
I have a problem with JS. I want to get (or set) the values of the fields in the document.
when I use syntax like:
document.forms[0]..value
console puts an error that has no properties.
And when I use
document.forms[0].
there are no error messages on the console, but the values aren set (and when I just want to alert the value that way, it shows me “undefined”).
Please tell me, what’s the problem ?
With best regards,
Arson
Subject: Elementary problem with JS
You syntax is correct
document.forms[0].FieldName.value = ‘ok’
will set the value for FieldName.
Take in mind:
  • FieldName is case sensitive. If your fieldname in Notes is declared as FIELDNAME, you should refer to it in JS as document.forms[0].FIELDNAME.value
  • The field should be editable
  • The field should not be hidden with a hide/when formula (if it is hidden with the HTML-tag type=hidden you can refer to it in JS)
Regards,
René
Subject: RE: Elementary problem with JS
I can’t make it invisible either with div tag (and stype=“display:none”) or
any suggestions? I know it’s a easy question but i work for th first time with such things so please, be kind ;]
With best regards,
Arek
OK, it works…
I’ll give the step-by-step solution here so other newcomers could use it as a tip:
First, I put a with just one property: display:none for the id of my div, so:
#invisible { display:none }
Then I use div to hide the content:
here you put Your things You want to be hidden
everything except the things should be marked as pass-thru HTML (text menu from the main bar).
Now I can access every field hidden that way with JS. If any filed will be hidden using “hide-when” properties, then their values won’t be sent to the browser from the server. So You won’t have access to them.
I know it’s an elementary case, but I hope it will help anyone with similar problem as I had.
With best regards,
Arek
Hmmm…I’ll give it a try.
I have a question about that. I know that I could hide the fields with
tags with style=“display:None” and mark the text as pass-thru HTML text. but should the fields be also marked as pass-thru HTML ? because if not, they are shown on the screen
With best regards,
Arek
