Element.click() not working in Firefox
how do a JS code simulate a mouse click on “element_ID” gif button?
In IE element_ID.click() is working fine. Problem onlywith Firefox. Any work around?
— my JS code for onKeyDown event –
if(someConditionTrue) element_ID.click();
TIA.
Subject: element.click() not working in Firefox
No, that’s NOT your code. Post your ACTUAL code if you want help with this.
Subject: RE: element.click() not working in Firefox
further test shows that the problem related to Notes/FireFox related. =====JS in plain html working in IE/FF ==========
======= Notes JS not working ========
event: onKeyPressed of the last field.
code: doSomething(event);
Subject: element.click() not working in Firefox Solution
The solution is pretty much simple, instead rewriting the code etc… I created a text button with style: ‘no display’ and then attach the same @command([ToolRunAgent];“agent”). This way the newly added button wont be clicked unless called from the function.
Here is the url in detail http://mysite.verizon.net/sureshvkumar/myindex.htm
Hope this helps …
I found the solution, its pretty much simple, instead of porting the code etc… I created a text button with style: no display and then attach the same @command([ToolRunAgent];“agent”). This way the newly added button wont be clicked unless from the function.
Hope this helps others save their time…
