EffectiveUserName problem
Bit of a strange problem with my web agent. I am trying to sign the section on the form completed by the user, but it seems to be putting the name of the person who signed the agent instead!?!?
Can anyone help me out getting this working?
Code :
Sub Initialize
Dim db As NotesDatabase
Dim doc As NotesDocument
Dim status As Integer
Dim nam As NotesName
Dim strContract As String
Dim StrItemNo As String
Dim strJobNo As String
Dim QtyChecked As String
On Error Goto errorHandling
Set nam = session.CreateName(session.EffectiveUserName)
status = Cint(doc.status(0))
strContract = doc.ContractCode(0)
strItemNo = doc.JobItemNo(0)
strJobNo = doc.JobOrdNo(0)
If status = 0 Then
	'New Doc - so set status to 5
	doc.status = 5
	'Since this is a new document - run the number generator to gen a number for the RIR
	doc.RIRNum = NumberGenerator(strContract,strItemNo,strJobNo)
	Call doc.save(True,True)
	Call HTMLEmailInspector(session, db, doc)
	Exit Sub
If status = 5 Then
	If doc.InspComplete(0) = "Yes" Then
	'QA section - set status to 10
		doc.status = 10
		doc.InspSigned = nam.Abbreviated
		doc.InspSigDate = Now
		Call doc.Save(True,True)
		Call HTMLEmailLeadEng(session, db, doc)
		Exit Sub
	Else
		Exit Sub
If status = 10 Then
	'Relase for Manufacture - set status to 15
	If doc.QComplete(0) = "Yes" Then
		doc.DocSigned = nam.Abbreviated
		doc.DocSigDate = Now
		doc.status = 15
		Exit Sub
	Else
		Exit Sub
If status = 15 And doc.RFMQComplete(0) = "Yes" Then
	'Release for manufacture - stores - set status to 20
	doc.status = 20
	doc.RelSigned = nam.Abbreviated
	doc.RelSigDate = Now
	Call HTMLEmailStoreman(session, db, doc)
	Call HTMLEmailTransporter(session, db, doc)
	Exit Sub
If status = 20 Then
	'Close Off - Status 21
	doc.status = 21
	doc.StoreSig = nam.Abbreviated
	doc.StoreSigDate = Now
	doc.RIRClosed = "Yes"
	doc.ClosedBy = nam.Abbreviated
	doc.DateClosed = Now
	Call HTMLEmailPlanning(session, db, doc)
	Call HTMLEmailLeadEngInfoOnly(session, db, doc)
	Exit Sub
errorHandling:
Print "Workflow-RIR Error Reports:"
Print Err & " " & Error$
Print "Error Generator Failed" & Chr$(13) & Chr$(10)
Print "Doc Type: " & doc.DocType(0)  & Chr$(13) & Chr$(10)
Print "RIR No: " & doc.RIRNum(0)  & Chr$(13) & Chr$(10)
Print session.EffectiveUserName
Exit Sub
Help is appreciated.
F1H
Subject: EffectiveUserName problem
Hello Friend,
Please check designer help for EffectiveUserName property
i.e.
For a script running on:
1> A workstation, this is the name of the current user.
2 > A server, this is the name of the script’s owner (the person who last saved the script).
3> The Web, this is the either the name of the current Web user (if the Run as web user property is checked in the Agent Properties box) or the name of the person who last saved the script.
Hope this answer your issue…
– Parikshit
Subject: RE: EffectiveUserName problem
Thank You!
Its working now…I havdn’t checked that ‘Run as Web User’ option in the properties, so it was just running it on behalf of the script owner!!
Thanks again for your help.
F1H
