Easysync Pro and Tungsten E : Name not valid
I’m trying to sync my brand new Tungsten E with Lotus Notes 6 via EasySync Pro 4.2.1 (French softs).
Unfortunatly, after the first sync, I’m totally unable to do another synchro.
I try the patch proposed by Lotus but I get a “Name not valid” error while in EasySync.
Any idea ?
Thanx
Guy
Subject: Easysync Pro and Tungsten E : Name not valid
I have never had any luck with EasySync Pro. I moved all my users to www.commontime.com’s mNotes. Works first time, every time. The most flawless sync’er I’ve ever used.
Subject: RE: Easysync Pro and Tungsten E : Name not valid
If I unchecked Calendar synchronization, I can repliquate my mail, but I can’t see them in the soft VersaMail.
And for the calendar, I don’t know.
Any clues ?
I have the same problem, if anyone have a solution, please posted here.
thanks
Hi french users,
I found a “solution” for this problem.
After applying the patch described in :
http://www-1.ibm.com/support/docview.wss?rs=0&uid=swg24006010
Copy the rLNEN.dll and rename the copy rLNFR.dll
Works like a charm now !
I know that there is a 4.2.2 release of EasySync but I don’t know if the problem is solved. I’ll try it asap.
Regards
Guy
It did not work for me, I found out that the Palm Software of a Zire21 do the job perfectly with the Tungsten E
Problem is that Patch is designed for English environment.
To make it work on a French platform, I had to extract files from patch zip file in “C:\Program Files\Fichiers communs\XCPCSync\Translators\3CmPlm” directory and then rename rPalmEN.Dll file as rPalmFR.Dll file replacing existing one.
