Subject: There are some other things to try
First, does frame ‘right’ within frameset ‘Main’ have a default content set to some other view.
(Apologies if that was what you meant by
“All the default target view is set to right in the frameset.”
I assumed this related to targets)
Having ANY view open in the correct frame seems a good starting point.
Then I would try some other combinations of parameters,
in particular
Call uidb.OpenView(VGoto, , False , True )
or
Call uidb.OpenView(VGoto, , True, True )
both these seem plausible from the help (see below)
Let us know how you get on
Call notesUIDatabase.OpenView( viewName$ [, key$] [, newinstance] [, replaceView] )
Parameters
viewName$
String. The name of the view you want to open.
key$
Note This parameter is new with Release 5.
String. Optional. The value to scroll to.
newinstance
Boolean. Optional. True to open the view in a new window if it is already open. False (default) to give focus to the already open view.
replaceView
Note This parameter is new with Release 5.0.4.
Boolean. Optional. True to replace a different open view in its window. Otherwise, opens the view in a new window. You cannot replace the view you are in.
