DXLImporter Problem
I´ve exported a database to DXL and tried to import, when I got the message “DXLImporter failed”. The problem was, that the DXL attributes “activelinkcolor”, “visitedlinkcolor” and “unvisitedlinkcolor” are not allowed for subforms.
I haven´t found any way to set these attributes in the Designer. They were only active by two of my subforms. Even when I export the database and import it without any change, it doesn´t work. The DXL Exporter exports the properties, but the importer doesn´t know them.
But if the exporter exports them, Notes should know them. So I modified The domino_8_5_2.dtd and the import worked!
I´ve found a workaround for my problem, but the problem should be fixed by IBM in the next release.
Regards
Joerg
