DWA DST problem
My servers have the multi-language pack on them. The hotfix for DWA DST, DWAHF_v6.55x_455.002_DST.zip only has the inres6_en.dll in it. I also need the inres6_fr.dll to fix my DWA. Where can I find this new DLL.
Subject: DWA DST problem
The only version available for the moment is in english.
JYR
Subject: RE: DWA DST problem
Do you know if there could be any problems if I install the hotfix and do not have the inres6_fr.dll installed.
Will the french mail file still work in DWA for the calendar.
