DWA Archive link problem
HI friendsi have setup Policy based archiving on server…
but when i click on Archive through inotes it does not open the appropraite link… my server version is 6.5.1 …
while policy is working as desired…
i have searched the forum … found quite a few people having same problem… but no solution…
Thanx for help
Shanbhu Narayan
Subject: DWA Archive link problem
Here is what we have found. we have over 3500 iNotes only users…we create a policy to archive on a DIFFERENT server…the archive policy works but the link in the iNotes page always points to the same mail server…kind of defeats the purpose of having data archived if it is on the same machine. There is no place to modify what this archive button does…our workaroundif the url says to go to : http://server1.etc
have users modify the URL to http://server(NEW).etc
not very elegant but it does work.hope this helps
Subject: RE: DWA Archive link problem
But my Archives on same server still it does not open the Archives??? it opens some wierd link which does not have any meaning…
Shambhu Narayan
Had a similar issue. Make sure you have server-based archiving enabled in the client’s archive settings, and point to the archive server. This is the only way I could get the iNotes archive link to work. The only problem with that is once server-based archiving is enabled, the user can’t select additional docs to archive. The 6.5.4 client is supposed to fix this issue though.
