I have an Excel VBA Script that opens a Lotus Notes e-mail then uses the Application.SendKeys command to type a message. It works fine with Lotus Notes 7, but I see duplicate key strokes with Lotus Notes 8. If I disable the new features of Lotus Notes 8 using the “notes.exe -SA” start up command it works ok. Below is an expample of the results. Any ideas on how to fix this?
Design Reviewwwww Folddddddddddder Contents:
· Entire Project Foldeeeeeeeeerrrrr
· GerrrbToooool Commmmppaaaaaaaaaarison File
· TGZ fileeee bbbeffffffore and after rebbbbbbbuild
· PCB Drawing Check Printttttttt
· Design Review Form
