Duplicate attachment problem
I need to process all the attachments from the selected document. I have written following code :
Forall item In QAWBDoc.Items
	If item.Type = RICHTEXT Then
		Set rtitem = QAWBDoc.GetFirstItem(item.name)
		Set navigator = rtitem.CreateNavigator
		Set rtobject = navigator.GetFirstElement(RTELEM_TYPE_FILEATTACHMENT)
		While Not rtobject Is Nothing
			If rtobject.Type = EMBED_ATTACHMENT Then
				Call ProcessAttachment(QAWBDoc, rtitem, rtobject, navigator)
				attCounts = attCounts + 1
				Call rtobject.Remove()
				Set rtonject = Nothing
				Set rtobject = navigator.GetNextElement()
		Wend
End Forall
ProcessAttachment => function doing some operations on the attachments. Once attachment is processed I need to remove it from database.
But if document have any duplicate attachment, or same attachment attached twice, then it is giving problem while removing attachments.
What can be the solution on this?
Subject: RE: duplicate attachment problem…
Can you please say more precisely what the problem is?
