Hi all,
I’m using DWA for our Domino servers,i have tested it with different platforms before releasing it to production environment,Win 98,2000,XP with IE 5.5,6.0,7.0,all working fine.
The problem is,when some of the users login,the screen showed “Redirecting…” then just stuck there,i have tried to enable their cookies to accept all,change settings in security page to allow ActiveX to run,but still no help,if i tell them to type the full path"http://abc.domain.com/mail/mary.nsf",the page can be opened successfully in this circumstance.anyone got an idea about this?
Besides,some of them got another problem,they can login successfully,but their mail page is showing a half only,it’s like the header" Domino Web Access" then it’s nothing below,at the status bar of IE,it says"opened but with errors" something.i have tried the thingy above as well(Cookies,Activex),and told them to use Sun java instead of the Java VM,but still no help,anyone knows wut happened?
Thanks for all the help in advance.
Whisker
