I have never seen this problem before, and I think I have installed on RH7.3 with no problems.
When I try and start the domino server for the first time (using /opt/lotus/bin/server or /opt/lotus/latest/linux/notes/serversetup) even from a script which changes to the /local/notesdata directory, under the uid of notes with the same group I get the following message:
./java -ss512k -xoss5m -cp j.hall.jar: cfgdserver.jar : notes.jar lotus.domino.setup WizardManagerDomion -data /local/notesdata
Please edit your shell’s DISPLAY enviroment variable to reflect an unlocked terminal that you would like to launch the domion setup program on.
- warning all runtime debug info will be logged to /local/notesdata/setuplog.txt
As far as i know this this is just a standard RH7.3 install, with no graphical interface. I didn’t install the OS, so is there something missing from it?
thanks
-b
Subject: Domino on RH7.3 problem with starting a fresh install.
I was under the impression that Domino 6 required a GUI. A quick Google search produced the following:
"From: “Tom H Smith” abner@austin.rr.com
Date: Thu, 12 Dec 2002 20:19:56 -0600
Subject: Re: [suse-domino] Domino R6 on SuSE 8.1 - Installation - DISPLAY environment
The setup is no longer browser-based in R6. You need to export your
display (something like the following):
DISPLAY=:0.0
export DISPLAY
if you’re doing this locally. Otherwise you’ll need a machine name before
the :0.0.
Then when you run http httpsetup it’ll pop up a swing-based GUI thingy to do
all
the same configuration steps as in the browser before. I had to find this
out
the hard way myself.
HTH,
Tom"
–jeff
If you have no X on Linux use -listen and connect with remote Server Setup (Part of Admin Client installation)
