Domino & IIS6 in same machine
Can somebody help me with implementation of IIS6 and Domino http in same machine? I’ve searched the forum but looks like most of entries are for IIS5 (there is a slight difference) and also for Domino and IIS in different machines.
Thanks in advance, Fatmir
Subject: This should help
Check this article I wrote some time ago:http://www-10.lotus.com/ldd/nd6forum.nsf/0/33bd348aab606b5785256cfb002c0ffc?OpenDocument
Subject: Domino & IIS6 in same machine
Hi Fatmir,
You can the use the different HTTP ports for IIS and domino.
Ex: 80 for IIS and 81 for domino
Subject: RE: Domino & IIS6 in same machine
Which will not suffice, if he wants to use IIS as the HTTP stack for Domino (which is not clear from the posting).
