Domino Directory does not contain required view
Hi!Something is wrong with our domino directory.
When setting up notes client, entering username and domino server to connect to, clicking next. Error message “Domino Directory does not contain a required view”
I’ve test to fixup nupdall compact etc names.nsf but nothing works :frowning:
Another problem with our directory;
“Username not listed in domino directory” for every incoming mail.
What do to? Can i debug? How?
Thanks!
Subject: Domino Directory does not contain required view
Sounds like it could possibly be a corrupt or missing ($Users) view. Sometimes it helps to actually delete the view, then replace design to recreate it. You might also want to grab a fresh copy of the pubnames.ntf template, in case the corruption is there.
If the message says, that a required view is missing, my first thought would be to refresh the design from the template (or try a replace if that doesn’t seem to help).
Subject: RE: Domino Directory does not contain required view
Already tried to refresh and replace design from template, same error
If you are running design as a scheduled task, that could just mean that the template is toast.
