"Domino Directory does not contain a required view"
I downloaded the trial version (english) of the Client.I installed it in another directory than my current one; everything went fine.
At start of the client, after I have entered my password (always twice by the way!?),
I get a message window “Domino Directory does not contain a required view”.
When I click “OK” the program is finished.
Which directory may be meant?
Is it on the client or on the server?
Btw, we are running on a 4.51 server - german version.
Can I use the version 6 client with this at all? I had tried it with a version 5 one
several months ago; worked fine.
Subject: “Domino Directory does not contain a required view”
I have exactly the same error trying to connect a 6.0.1 client to a 4.6.3 Domino Server, including entering the password twice. When I run the 6.0.1 with debug turned on I get the extended error “The requested function is not supported by the software on this server”. Below I have included the complete debug output. Any help appreciated.
ND6debug__2003_05_09@11_14_48.txt
(1-0 [1]) SERVER_AVAILABLE_LITE: (Connect to ServerName/Org/Org: 8 ms) (OPEN_SESSION: 0 ms)
2 ms. [26+32=58]
(2-26 [2]) NAME_LOOKUP(CN=UserName/OU=Org/O=Org,00000100): (Connect to ServerName/Org/Org: 13102 ms) (Exch names: 0 ms)(Authenticate: 4 ms.)
(OPEN_SESSION: 2 ms)
2 ms. [118+96=214]
(3-39 [3]) OPEN_DB(CN=ServerName/OU=Org/O=Org!!mail\username): 12 ms. [126+210=336]
(4-39 [4]) CLOSE_DB(REP4A256C07:0018A480): 0 ms. [14+0=14]
(5-39 [5]) NAME_GET_AB: 158 ms. [12+26=38]
(6-39 [6]) OPEN_DB(CN=ServerName/OU=Org/O=Org!!names.nsf): 10 ms. [126+210=336]
(7-39 [7]) CLOSE_DB(REP80256403:003E4A9B): 0 ms. [14+0=14]
(8-39 [8]) NAME_LOOKUP(CN=UserName/OU=Org/O=Org,00000102): 199 ms. [216+46=262]
(9-39 [9]) NAME_GET_AB: 6 ms. [12+26=38]
(10-39 [10]) OPEN_DB(CN=ServerName/OU=Org/O=Org!!names.nsf): 9 ms. [126+210=336]
(11-39 [11]) OPEN_COLLECTION(REP80256403:003E4A9B-NTFFFF0020,0000,0000): 19 ms. [32+34=66]
(12-39 [12]) READ_ENTRIES: 295 ms. [46+64474=64520]
(13-40 [13]) READ_ENTRIES: 15 ms. [46+23600=23646]
(14-40 [14]) CLOSE_COLLECTION(REP80256403:003E4A9B-NTFFFF0020): 0 ms. [12+0=12]
(15-40 [15]) OPEN_COLLECTION(REP80256403:003E4A9B-NT000001E6,0000,0000): 354 ms. [32+34=66]
(16-40 [16]) UPDATE_COLLECTION: 5 ms. [24+12=36]
(17-40 [17]) FIND_BY_KEY: 3 ms. [538+38=576]
(18-40 [18]) READ_ENTRIES: 2 ms. [50+52=102]
(19-40 [19]) OPEN_NOTE(REP80256403:003E4A9B-NT0001AFF6,00400000): 462 ms. [48+5136=5184]
(20-40 [20]) CLOSE_COLLECTION(REP80256403:003E4A9B-NT000001E6): 0 ms. [12+0=12]
(21-40 [21]) OPEN_NOTE(REP80256403:003E4A9B-NT0001AFF6,00400000): 217 ms. [48+5136=5184]
(22-41 [22]) CLOSE_DB(REP80256403:003E4A9B): 1 ms. [14+0=14]
(23-41 [23]) SV_INFO_GET_RQST: 210 ms. [14+138=152] (The requested function is not supported by the software on this server.)
(24-41 [24]) NAME_GET_AB: 20 ms. [12+72=84]
(25-41 [25]) OPEN_DB(CN=ServerName/OU=Org/O=Org!!names.nsf): 10 ms. [126+210=336]
(26-41 [26]) NAME_LOOKUP32(CN=UserName/OU=Org/O=Org,00040200): 2 ms. [112+138=250]
(27-41 [27]) NAME_LOOKUP(CN=UserName/OU=Org/O=Org,00040200): 4 ms. [112+190=302]
(28-41 [28]) NAME_LOOKUP32(* [3 more…],00040202): 2 ms. [144+138=282]
(29-41 [29]) NAME_LOOKUP(* [3 more…],00040202): 5 ms. [144+14=158] (Domino Directory does not contain a required view)
5 ms. [144+14=158] (Session Closed)
(30-41 [30]) SERVER_AVAILABLE_LITE: (Connect to ServerName/Org/Org: 13 ms) (OPEN_SESSION: 3 ms)
3 ms. [26+32=58]
(31-41 [31]) SV_INFO_GET_RQST: (Connect to ServerName/Org/Org: 27 ms) (Exch names: 0 ms)(Authenticate: 3 ms.)
2 ms. [14+138=152] (The requested function is not supported by the software on this server.)
(32-41 [32]) NAME_GET_AB: 11 ms. [12+72=84]
(33-41 [33]) OPEN_DB(CN=ServerName/OU=Org/O=Org!!names.nsf): 9 ms. [126+210=336]
(34-41 [34]) NAME_LOOKUP32(CN=UserName/OU=Org/O=Org,00040200): 7 ms. [112+138=250]
(35-41 [35]) NAME_LOOKUP(CN=UserName/OU=Org/O=Org,00040200): 4 ms. [112+190=302]
(36-41 [36]) NAME_LOOKUP32(* [3 more…],00040202): 5 ms. [162+138=300]
(37-41 [37]) NAME_LOOKUP(* [3 more…],00040202): 5 ms. [162+14=176] (Domino Directory does not contain a required view)
5 ms. [162+14=176] (Session Closed)
Edgar
I have determined a work around that has been confirmed by Lotus. First configure the 6 client so that it is not connected to a domino server, switch to your ID file that connects to your Notes Domain and then manually create a connection and location document. You will now be able to connect to your 4.x Server.
Grant.
