Domino Designer Help .nsf is very slow
When using domino designer help, occasionally it says “You cannont add a directory to your workspace” in a dialog box and sometimes the status bar says "Requesting address of »'.■ on " and then the server name. This takes a long time then the page diplays.
Has anyone seen this and does anyone have a solution?
Cheers
Adam.
