Domino Configuration Tuner problem
We’re trying to use the DCT tool to check our servers which are release 8.5 and 7.0.2FP2 on linux 2.6.16-0.12-bigsmp
This has been tried on different workstations running Windows XP, several times during the day.
Have tried different Lotus Domino servers
The report always fails with the rule
ServerInfo
Retrieve prerequisite server information
Is there something we’re missing?
Ian
The detail being
The Domino Configuration Tuner experienced an internal error while evaluating this rule.
It is possible that some of the server data that is retrieved in order to evaluate this rule could not be parsed. Sometimes these errors are transient. An attempt to scan the server again may result in successful evaluation of this rule.
; Line#: 33; Column#: 71
net.sf.saxon.trans.XPathException: XQuery static error in #…ultnotesini, “PartitionNumber”#:
Variable $resultnotesini has not been declared
Subject: checking with the development team on this problem
Subject: Any progress from the Development Team
Hi Brian,
Any news from the Development Team?
Ian
Subject: Re-created… similar setup
I have just tried DCT across our 7.0.2fp2 infrastructure from an 8.5 client and hit upon exactly the same error… any news from development ? thanks
Subject: Still a problem with DCT & $resultnotesini not declared
We’ve just tried running the DCT tool against a Lotus Domino server version 8.5 running on a Windows 2003 server and getting the same response.
Can anyone indicate what the problem may be,a nd how this can be addressed?
Details are
An exception occurred while running rule: ‘ServerInfo’
Many Thanks
Ian
Subject: Thanks Brian
Hi Brian,
Thanks for the update. Let me know if there is anything else you need.
Ian
Subject: Is there any fix
I’m having the same issue on an xp box going to 2 2003 servers one 8 one 8.5
