Can I enable sound when the domino server is down? How can I do this?
Subject: One way to do it
You could do it by buying a monitoring package that monitors and alerts, one I’ve used is http://www.ipsentry.com. You could install in on the server to monitor port 1352, and on failure send email, fax, page, launch an app, or .wav file. Keep in mind it works best on a separate machine, since if the server dies due to hardware failure it couldn’t generate an alert:-jmw
