Domino 8.5 Designer - stange problems
Did you ever encounter problems with the new designer? I right now tried to change the view selection formula of a view.
Whatever i did - the changes were not reflected to the database in the notes client, allthough visible in the designer.
Mayb it has something to do with the fact, that i copied a view to create one with a different selection.
I had this on some other databases and beeing very unlucky i just decided to go back to 7.02 designer.
I cut and pasted the views and that solved the problem.
At the moment i am very unlucky, as sucht problems do cost a lot of time.
Am i the only one, having such problems?
Regards
G.
