Domino 8.5.2 on system i v6r1
Hi Wondering if anyone can help I’m trying to install upgrade domino to 8.5.2 on a system i server v6r1 but when using the rstlicpgm command it always says object not restored
looking at the messages it says
RSTLICPGM LICPGM(5733L85) DEV(*SAVF) OPTION(12) SAVF(MYLIB/QNOTESRL)
*PGM objects for product 5733L85 option *BASE release *FIRST not installed.
Product 5733L85 option 12 release *FIRST not processed.
*PGM objects for product 5733L85 option 12 release *FIRST not restored
Objects for product 5733L85 option 12 release *FIRST not restored.
It works fine on system i v7r1 but the same error occurs on v5r4 I’ve checked through the prereqs and seems like they are all in place couldn;t find any fixes on fix central. Has any one else come across this problem.
Subject: Install *BASE 1st, then Option 12
Subject: Got it working
Thanks Evan that was it, I assumed that since we already had 8.5.1 installed that base was already installed but I tried it again and it worked cheers.
Subject: I didn’t have to run that command
I’ve got two i5 boxes running v6r1 and I just ran the setup.exe executable and when that finished ran UPDDOMSVR to do the actual upgrade. Both have gone flawless for me.
