Domino 7 XML: Date problem XSD_DATETIME not correctly converted
We have the following problem, building an XML service as part of SOA that handles date/times:
Using SoapUI 1.5, we are sending an XML request to a domino application, using the following code:
<soapenv:Envelope xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns:xsd=“http://www.w3.org/2001/XMLSchema” xmlns:soapenv=“http://schemas.xmlsoap.org/soap/envelope/” xmlns:urn=“urn:DefaultNamespace”>
soapenv:Body
  <urn:APPOINTMENTSET soapenv:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
     <STARTTIME xsi:type="xsd:dateTime">2006-12-18T15:36:54</STARTTIME>
     <ENDTIME xsi:type="xsd:dateTime">2006-12-18T15:46:54</ENDTIME>
  </urn:APPOINTMENTSET>
</soapenv:Body>
</soapenv:Envelope>
The problem is that the TIME part is false when retrieved from a lotusscript:
function ApointmentSet (StartTime as XSD_DATETIME, End Time as XSD_DATETIME) as Long
        Dim dts As NotesDateTime
        AppointmentSet = Err
        Set dts = StartTime.GetValueAsNotesDateTime()
        Msgbox "XML TSD/OT " & dts.LSLocalTime
The returned date is 12/18/2006 1:01:03 AM
The date is correct
The TIME is NOT correct
To be sure, I have already tried using a timezone or not, and fractional seconds, etc… Fuzzy behaviour. Also tried to return an XSD_DATETIME from server, to use the very same format as input (acutally, I even did a copy/paste of the reply > wrong result)
Is it a BUG? Any workaround?
Or did I miss something?
Thank you for your help
Subject: Domino 7 XML: Date problem XSD_DATETIME not correctly converted
I have the same problem.
From what I see in de lsxsd.lss file . . . there’s a bug in the XSD_DATETIME class. The call . . .
Right$(ME.getValueAsString, 12)
. . . should be . . .
Right$(ME.getValueAsString, 8)
Mmm, correct the lsxsd.lss file, re-compile and save your web service … and I think you’re done.
PUBLIC CLASS XSD_DATETIME AS XSD_SIMPLETYPE
SUB SetValueFromNotesDateTime (value As NotesDateTime)
	Dim xdtc As New XSD_DATATYPE_CONVERTER
	CALL ME.setValueFromString (xdtc.getXSDDate (value) & "T" & xdtc.getXSDTime (value))
End SUB
Function GetValueAsNotesDateTime ( ) As NotesDateTime
	Dim ndt As New NotesDateTime ("")
	Call xdtc.setXSDDate (ndt, ME.getValueAsString)
	if Mid$(ME.getValueAsString,11,1) = "T" then	' if there's a time part after the required CCYY-MM-DD
		Call xdtc.setXSDTime (ndt, Right$(ME.getValueAsString, 8))
	set GetValueAsNotesDateTime = ndt
End FUNCTION
END CLASS
Subject: RE: Domino 7 XML: Date problem XSD_DATETIME not correctly converted
One more correction in the lsxsd.lss file, in the XSD_DATATYPE_CONVERTER.setXSDDate method.
’ Set the date part of a NotesDateTime From “CCYY-MM-DD …”
Sub setXSDDate (ndt As NotesDateTime, xsddate As String)
If Not ndt.IsValidDate Then ndt.LocalTime = ""
Dim timeonly As String
timeonly = ndt.TimeOnly	' preserve the time part
Dim newDt as New NotesDateTime( Mid$(xsddate,9,2) & "-" & Mid$(xsddate,6,2) & "-" & Left$(xsddate,4) & " " & timeonly )
set ndt = newDt
