Domino 7 & 8 in same machine
Dear all,
I’m running a Domino R7 server. I want in the same machine to install a Domino R8 server.
– How is it possible? I have to use “partitioned server” feature?
– Are there any possible conflicts if I install all in one machine?
– Where can I find instructions?
Subject: Re: Partition
Hi Panos,
This is quite an undertaking and involves some risk. Do you have a Support contract with IBM? If so, I would recommend calling in and requesting to speak with the Server Core team regarding configuring Two instances of Domino on a Partitioned Server. They will be able to best assist you with this matter.
If you do not have a support contract, let me know via response and I will see if I can find the most detailed instructions for you.
Good luck Panos!
Regards,
-Bob
Subject: Re:
Thank you very much for the response. Unfortunately I do not have a Support contract with IBM.
Also from Domino Help I found that you can only use Partitioned installation if you want to install the same version of Domino (ex. run 2 instances of Domino 7). What I want is Domino 7 and Domino 8 servers run on the same machine.
If you could send me any instructions it would be great!
Subject: Re: Domino Install
Hi Panos,
I know you can install multiple versions of Domino under the UNIX Platform, but I’m not 100% savvy with the configurations of partitions and such.
Below, I have included one link to IBM’s external information site. This is a great tool to have and answers vast amounts of questions. This link should specifically bring you to the section regarding Installations of Domino on Windows:
http://publib.boulder.ibm.com/infocenter/domhelp/v8r0/index.jsp?topic=/com.ibm.help.domino.admin.doc/DOC/H_INSTALLING_DOMINO_ON_W32_PLATFORM_STEPS.html
For highly detailed information on Partitions, search this Infocenter link above for “Partition” and it will bring up a wealth of information that should help you configure your environment.
This second link is for a Technote that outlined the only information I could really find regarding setting up partitions:
Lotus Software Knowledge Base Document
Title: How do you add another Domino partition to a partitioned server
Doc #: 1279724
URL: http://www.ibm.com/support/docview.wss?rs=899&uid=swg21279724
I hope this information helps Panos - I know I use the Infocenter quite a bit in my troubleshooting!
Good Luck!
Regards,
-Bob
