Domino 6.5.1 linux jvm problem
hi,i have a problem with the http server task on domino 6.5.1 (suse linux sles8). the task finished with this message:
JVM: The Java Virtual Machine creation returned an invalid JVM machine pointer.
JVM: Java Virtual Machine failed to start
HTTP Server: Error Loading Java Virtual Machine
HTTP Server: JVM: Missing entrypoint in JVM runtime library.
java -version ist executed as root and notes user with this banner:
java version “1.3.1”
Java™ 2 Runtime Environment, Standard Edition (build 1.3.1)
Classic VM (build 1.3.1, J2RE 1.3.1 IBM build cxia32131-20020622 (JIT enabled: jitc))
how can i resolve this problem?
Subject: domino 6.5.1 linux jvm problem
Hi
Maybe this will help you out
http://cymulacrum.net/writings/java/ibm-java.html
After a long search in Lotus forum a found nothing useful for this problem.This is a pity because Lotus should take care about these problems.
Anyway I found a solution that works for me on another forum.
It seems that the library libjava.so in /opt/lotus/notes/latest/linux confilicts in some way.
I renamed it in libjava.old and now it works like a charm.
