Domino 6.0.3 adminclient 6.5 problem
I’ve installed Adminclient 6.5 on Server 6.0.3. Now I’ve many problems. Every 30-60 minutes the server cancelled. I’ve deinstalled the Adminclient and restarted the server, but the same problem. Has anyone an idea how can I solved this problem without reinstalling the server
Subject: domino 6.0.3 adminclient 6.5 problem
did you install the admin client on the server? or on your workstation to admin the server? check the notes.ini for strange enties.
what os are you on the server? maybe when you are on W2000 you have to set some things on the dosbox
Subject: RE: domino 6.0.3 adminclient 6.5 problem
I installed the client on the server. what I’ve had to check in the ini ? Server are W2000
Unless you used totally separate directory structures, you probably overwrote some 6.0.3 files when you added the client. It may have also done something to registry entries (???).I would recommend doing a server install. At least install Domino 6.0.3 into the same structure. I see little possible downside to this (other than taking the server off-line for a half hour). Even better would be to put Domino 6.5.1 on it while you are there. I don’t forsee any likely problem with this approach either. It is a routine upgrade with no compacts or other required steps.
