DOLS sync using Network Dialup connection
We want to have offline dols subscriptions. Users will connect via a 3G modem to an ADSL line to access a Domino sever. Synchronization will be scheduled. Is there a way to have the 3G network connection auto invoked by the Sync Manager when the scheduled sync runs? With Notes Client replication this can be done by creating a “Network Dialup” connection which is invoked in the background and disconnects after replication - can the same be done for DOLS?
Subject: You might be able to do this with a custom dolnames.nsf
Search the technotes. There is a way to create a custome dolnames.nsf that will have connection documents, etc. in it. I would bet that would solve your problem.
Subject: RE: DOLS sync using Network Dialup connection
Thank you for providing us this feedback. This is not currently supported in the product. We will evaluate this as a future enhancement.
Subject: DOLS connection documents
Hi, Rahul, thanks for the response. Are you responding on behalf of IBM tech. support - or is there possibly a way of customizing connections in dolnames.nsf?
