Does dojo.byId from within a library.js work?
i have a library.js as a resource in my xpage.I have functions that need to get html controls as input text, listbox, etc…
Into de Libreary.js i tryed :
document.getElementById(“#{id:eee}”)
and
dojo.byId(“#{id:eee}”)
didn’t work!
i get a null value!
Help please
Diego
Subject: Server Side or Client Side
Server Side or Client side script library? It definitely won’t work for server side script libraries. I think there is a way to make it work on client side. Do a search of Matt Whites blog, i think I saw something there that might help.
Subject: resolved
Thanks Declan
Really, the problem was that, i has:
dojo.byId(“#{id:XXX}”)
into a client javascript library resource.
Finally, i understood that ("#{id:XXX} don’t get transformed to real IDs on de server, because, server does’t do it for client librearies.
Sorry :slight_smile:
