@DocumentUniquID on create problem
I am creating a new document on the web. I have a computed field called DocID wit the formula @Text(@DocumentUniqueID).Before a save, this displays the docID. When I save the doc, the unique ID changes.
Is this right?
What I am trying to do is on save, do something, then save the doc, then open the document in edit mode by referencing the doc id, but it keeps frikkin changing. Any help?
Subject: @DocumentUniquID on create problem
Yes.Its a normal behaviour when documents are composed on the web, they get a temporary unid which is changed when the document is saved.
http://www-10.lotus.com/ldd/46dom.nsf/55c38d716d632d9b8525689b005ba1c0/e7e9f5d94f99a04585256e3d004d17d8?OpenDocument
cheers !!
Ashish
