Documents not in Index using FTSearch
We have seen strange behavior lately whereby the database index is being updated via a script. User logs into web and the navigation pane we have calls the script to update the index, thus showing the correct documents. However, some documents are left out of the index, but when you check the unindexed documents, it is -0-. The only way they get added to the index if we make change to a field and save, or delete and recreate the index. Some documents that have changed since the last update, do not display the correct information as the index does not recognize the change.Anyone heard of such bizarre behavior?
–Ben
