Hello there developers, I experienced this problem. I turned on document locking on a database. From that moment, I found that user with right “Write public access document” (and having Author access level) cannot edit public documents (documents with field $PublicAccess set to “1”). It seems like Notes has problem with editing public documents while users have Author access to database.
After turning locking off, the problem disappeared.
Thanks for any advice.
Michal Rovnanik
