Document does not appear in view when it has 15 categories?
I have a couple multivalue fields on a form that I am permuting into a list of categories under which the document should appear in a view:
FIELD InvoicingOffice:=“JN”:“IO”:“PH”;
FIELD BusinessLine:=“PD2”:“TR2”:“IC2”:“FD2”:“FR2”;
BusinessLine is a a keyword with synonyms field and InvoicingOffice is just a multivalue field.
Formula for first categorized view column.
(InvoicingOffice+“-”)+BusinessLine
Underneath the category the single ServiceCode on the document is displayed. There are multiple service code documents which will fall under the same category.
The document only appears under five categories in the view:
IO-TR2
JN-PD2
PH-FD2
PH-FR2
PH-IC2
Can anyone offer insight on this issue?
Thank you,
Rich
Subject: Document does not appear in view when it has 15 categories??
Richard,
Use (InvoicingOffice + “-”) *+ (BusinessLine)
regards,
raphael
Sorry, false alarm…
The view category column should have been
(InvoicingOffice+“-”)*+BusinessLine
