The following code works, and the resulting response documents use a form that is of type “Response,” and the response documents also have the correct $REF, and the view correctly displays response docs in a response hierarchy. BUT, the resulting response docs are being saved as parent docs, and they are not showing up underneath the parent! Here is the code. HELP! I’ve used doc.makeresponse quite a few times successfully, too!
Dim thisdb As notesdatabase
Dim regdb As notesdatabase
Dim orgview As notesview
Dim session As notessession
Dim thisdoc As NotesDocument
Dim regdoc As notesdocument
Dim orgdoc As notesdocument
Dim coll As NotesDocumentCollection
Set session = New notessession
Set thisdb = session.currentdatabase
Set regdb = New NotesDatabase("IDXNET/BOSTON/IDX1", "IUC\UCReg2005.nsf")
Set coll = thisdb.UnprocessedDocuments
Set orgview = regdb.GetView("Clients")
Set orgdoc = orgview.GetDocumentByKey("IDX",True)
For i = 1 To coll.Count
Set thisdoc = coll.GetNthDocument(i)
Set regdoc = regdb.CreateDocument
regdoc.Form = "STAFF"
regdoc.StaffName = thisdoc.StaffName
regdoc.ENUMBER = thisdoc.ENUMBER
Call regdoc.MakeResponse(orgdoc)
Call regdoc.ComputeWithForm(True,False)
Call regdoc.Save(True,False)
Next i
Subject: doc.makeresponse problem!
Hi Tricia,
Two things:
- flag = notesDocument.Save( force, createResponse [, markRead ] )
In your save method, you are setting createresponse to false.
- If number 1 above doent do it …As a test try removing the line to ComputeWithForm, and see if it works. There could be something that you are doing in the form that affects the hierarchical nature.
Subject: RE: doc.makeresponse problem!
Actually, #1 doesn’t have anything to do with it. That param is only used in dealing with replication/save conflicts. It will not negate the explicit use of doc.makeresponse.
I tried calling regdoc.Save(True,True)… nada. Then I commented out regdoc.ComputeWithForm(True,False) and still the hierarchy is messed up.
DUH!!! I apologize, but doc.makeresponse was working perfectly well!! My view was relying on a field to properly categorize, and I forgot to set that field! Sorry! Here is the resulting code, which works very well!
Sub Initialize
regdoc.StaffName = thisdoc.UC_AllIDXPresenters
regdoc.CIS_CustMne = "IDX" 'needed to categorize the view
regdoc.CIS_CustNm = "IDX Systems Corporation"
Next i
