Display shared image on web problem
I am attempting to display an image (based on a department code) on a webfom. The the image is stored in the “Shared Images”
But its not producing what i expected…
I have the following code in “computed text” with passthru html.
Code :
svr := Server_Name;
db := @DbName;
@If(Department =“HR”; files := “logo1.jpg”;“”);
“http://” +Svr + “/” + db + “/” + files
Result :
http://www.domain.com//logo1.jpg, http://www.domain.com/pathname\dbname.nsf/logo1.jpg
ideally i want the second result only and to display the logo and not the text …
any sugesstions greatfully received.
Thanks R
Subject: display shared image on web problem …
It is a minor formula thing to get used to. What you need is
svr := Server_Name;
db := @DbName;
(“http://” +Svr + “/” + db + “/”) + files
Subject: RE: display shared image on web problem …
hi,
same result i’m afraid…
R
I had the right idea, but the wrong culprit. You should make it:
svr := Server_Name;
db := @Subset(@DbName; -1);
The problem is that the @DbName is a list of two elements, the first is the server (blank in your case), the second is the filepath. So, in your instance, the two elements propogate through the list. Of course, you might be even better off using
svr := Server_Name;
db := @WebDbName;
Arghhh…
@WebDbOpen … that sorted out the duplicate.
So now i have the correct url, but how to display the image from the “Shared Images” instead of just the url ??
And the answer is :
svr := Server_Name;
db := @WebDbName;
@If(
Department =“HR”;files := “Logo1jpg”;
Department =“Test”;files :=“Logo2.jpg”;
Department =“-”;files := “no_image.jpg”;
“<IMG SRC=” + “http://” +Svr + “/” + db + “/” + files + " WIDTH=" + “"100"” + “HEIGHT=” + “"150"” + “>”;
Many Thanks
R
svr := Server_Name;db := @DbName;
@If(
Department =“HR”;
“http://” +Svr + “/” + db + “/logo1.jpg”;
hi,
again , same result i’m afraid…
R
am i missing somthing here … ??
Among other things, you haven’t indicated that you are calling an image – the code is just creating a URL. And that URL is going to be a “stub” pointing to the database if the department is not HR. Your code should probably look something like this instead:
file := @If(Department=“HR”; “logo1.jpg”; Department=“SomeOtherDepartment”; “some_other_image.jpg”; “”);
@If(file=“”;“”;“<img src="/” + @WebDbName + “/” + file + “">”; “”)
