Display lock after few minutes - Beta 2 OS/X
Hi there,
we are suffering from the problem, that the Notes client always locks the display after a few minutes - even when one is writing a mail!
The log out after xx minutes setting under preference does not have any influence on this matter. Regardless of its setting the user gets locked out after a few minutes. We are using the OS/X keychain to save the notes credentials. The keychain is not set to auto-logoff after some time.
Are there any other settings which will do the trick or is it a bug?
Thx for your help, Rado
Subject: Display lock after few minutes - 8.5 OSx
We are seeing this in 8.5, could not find SPR KLSG7KQ7MNJ referenced in current fix lists… any idea on if and when this will be fixed?
Subject: Thank you for reporting this issue!
This is a known issue ,SPR ID#KLSG7KQ7MN.And there is a possible work around that set the logout value to 120 minutes.Please let us know if it is workable for you.Thanks
Subject: Not me.
FWIW, I do not suffer this behavior. Running 8.5 public beta 2 on a Macbook, OS X 10.5.5
