I have a help database in order to use with my application and I’d like to display this help with the same layout as we now have with Notes 8.5 help - when the db opens as a “sidebar”.
I’m using the @Command [OpenHelpDocument], as specified in Designer help and I’m not getting the same behavior.
I also checked out the mail85 template and it’s using the same @command, but with a little difference - using the [HelpClient] keyword instead of the database path.
Is there something I can do (configuration, new parameter, etc…) to have the same behavior?
Thank you!
Best Regards,
Gustavo Pagotto.
