Display contents of Body field in view column
I am wanting to display the contents of a MIME type body field in a view. We are wanting to export emails to a spreadsheet and I was hoping to do it thru a view. @abstract doesn’t work.
Any ideas?
Subject: RE: Display contents of Body field in view column
You can’t display rich text in a view, not noways not nohow. If you copied the data to a text field then you could display the text field. However, I wouldn;t advise that approach in your case. Just bite the bullet and export data directly from the documents, e.g. using LotusScript, instead of trying to use the view entries.
Subject: Nancy, did you find a way to export MIME?
Are you exporting MIME content incluiding all Types and Subtypes? Tx.
Subject: Display contents of Body field in view column
Try @Text instead.
