hcl-bot
1
Hi
We have a domino 6.5.3 FP1 server (upgraded from R5.0.13)and Lotus R5 clients
A directory catalog has been setup to include users from our parent company.
When a person tries to send email to users in the dir catalog it comes up with an error saying
“User not found in address book or any domino directory” this only happens to some users.
I have tried updating the index etc…of the dircat but nothing seems to work… is my only option to recreate the dircat ?
Is this issue caused die to upgrading the domino server ? cause earlier it was working fine
Thanks in advance
Shamitha
hcl-bot
2
Subject: Directory Catalog Issue - Pls Help
Hi Shamita,
currently I am aware of two bugs regarding this problem:
Ambiguous Names Dialog Box Not Working As Expected with Offline Directory Catalog SPR# CSMH65WPRX :
http://www-1.ibm.com/support/docview.wss?rs=474&uid=swg21188776
can be avoided with client version <6.5.3
SPR# MPUL696SSF Soundex Breaks Online & Offline Dircat Name Lookup Results On LastName Firstname
if this is your problem then I may have a “workaround” for you, I personally did not test…
can be avoided with server version 6.5.1. and maybe also with 6.5.2, but the bug is inside 6.5.3.
Cheers,
Markus
