Hi guys,
I have a Java application that uses DIIOP to connect to a Domino server and reads mail files, etc. I’m not using each user’s credentials for making the session but an administrator’s credentials and then try to get each user’s mailbox from the server.
I have two Domino servers in my environment A (transducer) and B (Brutus). Server A is the one that is running DIIOP and I’m connecting to from my Java client. Server B is an additional server that is known to A (via the server document).
Now when I make a connection to A to read mail files that are located on A, I have no problems and the application accesses the mail files and reads the mails properly. The problem is when I try to read a mail file from server B through server A. Here’s my code:
Database db = null;
View view = null;
ViewEntryCollection vec = null;
DbDirectory dbDir = null;
try
logger.logit("DominoSessionBean.getMail[] mailFile is " + mailFile);
db = session.getDatabase(mailHost, mailFile);
if (!db.isOpen()){
try {
db.open();
} catch (Exception e) {
logger.logit("Could not open: db:"+db);
logger.logit(e.getMessage());
// TODO: handle exception
view = db.getView("($Inbox)");
mailFile and mailHost are two variables that are read from each user’s document. For those located on server A the value is:
CN=transducer/O=cablesedge
And for those located on B the value is:
CN=brutus/O=cablesedge
As transducer and brutus are the names of my servers. The exception that happens when I try to get the “$Inbox” view for users that are located on Brutus, I get the following exception.
NotesException: Database CN=brutus/O=cablesedge!!MAIL\RD.nsf has not been opened yet
at lotus.domino.NotesExceptionHelper.read(Unknown Source)
at lotus.domino.NotesExceptionHolder._read(Unknown Source)
at lotus.priv.CORBA.iiop.RepImpl.invoke(Unknown Source)
at lotus.priv.CORBA.portable.ObjectImpl._invoke(Unknown Source)
Any help with this will be greatly appreciated.
