Can Any one explamin me what is the difference between reserve filed and filed
Subject: Difference Betwwen Reserve Field and Field
Not totally sure if I understand the question. However if you are asking about Reserved Fields.
These are fields with a pre-defined functionality, sometimes created automatically by Notes and are sometimes prefixed by a $ or $$.
For example “SendTo” is a reserved field as it is used to contain the names of people you wish a document to be emailed to, and is recognised by the server when routing mail. The Domino Designer help has a whole long list of them.
Fields (non-reserved) is basically everything else.
HTH - Rufus.
