Can I get the difference between @DeleteField and @UnAvailable functions. According to Lotus Help they both perform the same thing i.e delete fields from document along with invisible fields.
I have tested out with various possibilities of creating a field using @setField and then delte it by using the above functions and they did the same thing.
