Difference between CopyItem method and doc1.field2=doc2.field2
All is in subject. I want to know the difference between this two syntax :
Call doc1.CopyItem( doc2.field2 )
And
Thanks,
Julien
Subject: Difference between CopyItem method and doc1.field2=doc2.field2
if there is no field already created in doc1 then
doc1.field2 = doc2.field2
and
will produce same result.
But if doc1 has already field “field2” then
will create another field in doc1 and there will be 2 fields in the document with the same name but
will only replace the value of field2 in doc1 with field2 value in doc2.
Hope you will got the idea.
Subject: RE: Difference between CopyItem method and doc1.field2=doc2.field2
cool Nasir,
Thanks for your help !
Actually there are other differences. The syntax
only copies the field value, and not any flags associated with that field. For instance, if field2 is a Readers field, this will not make the new item a Readers field if it wasn’t already.
The value copy with = is not exact for all datatypes. If the original field contains a date only, then the copied value will contain a date and a time (12:00:00) and the timezone of the computer running the code.
The = syntax won’t work for a rich text field.
